Bending without Bender
Beitragvon Benoh » Mo 25. Jan 2010, 17:16
hello FORUM,
a small matter to collect good ideas! :geek:
what are the different ways to bend a blade aluminum c-rotor?
for the next project : a C-rotor H 150cm D 110cm
i use for blades an aluminium sheet thickness 3mm, is quite rigid
and I especially do not have a bender!
Benoh
Re: Bending without Bender
Beitragvon kalli51 » Di 26. Jan 2010, 18:42
hi and welcome Benoh, this 3mm aluminum is very thick material ,is hard to bend without a sheet metal bender ,may you try with a pipe between to wood-beams and you use a screw clamp too ;)
best regards Kalli from Norway
kalli51
