(had some time & some sun on the solar panels)
+ Improved mppt tracker. - The vasonline way (tm)
Die kiste lauft güt
(just joking
Still to to do:
- WDT
- Would like to reduce the cpu load of the CCPRL formula.
HI-TECH C Compiler for PIC10/12/16 MCUs Version 9.81 Release Notes
Delays and the watchdog timer Note that if the _delay feature is used to insert a simple delay sequence or
loop, the CLRWDT instruction may be used in this sequence. If the watchdog timer is not being used, this
is of no concern. If the watchdog timer is enabled, then be aware that delays may reset its timer.
Deze delay_us doet een CLRWDT() ! Getest & werkende bevonden.
