my first cycloidale vawt
Beitragvon haegeman » Di 11. Aug 2009, 17:45
this is my first model cycloidale wind turbine
with this model ,I have can raise 217 kg to the ground ,to make that I have placed a pulley from 7cm under the axis from the rotor and with another pulley and one cord ,the turbine have raise 217 kg at 2.5 meter hight in 3 sec.
the dimention is 192 cm diameter and the five blades is 84 cm large /96 cm hight.
the problem for a good test is that I don't know how much wind there was.
haegeman_l@skynet.be
Afbeelding 030.jpg (35.24 KiB) 11673-mal betrachtet
haegeman
Re: my first cycloidale vawt pulley and brake
Beitragvon haegeman » Di 11. Aug 2009, 17:53
thi is pictures from my pulley system and the two different brake that I use to make the first test
Afbeelding 038.jpg (50.13 KiB) 11666-mal betrachtet
Afbeelding 237.jpg (26.77 KiB) 11666-mal betrachtet
Afbeelding 334.jpg (46.48 KiB) 11665-mal betrachtet
haegeman
Beitragvon jb79 » Mi 12. Aug 2009, 10:06
Nice idea with the brake!
Can you take picures of the blade adjustment system for us please?
Beitragvon haegeman » Mi 12. Aug 2009, 17:49
first model with chain
Afbeelding 046.jpg (23.63 KiB) 11592-mal betrachtet
my first vawt type savonius
haegeman
