von GoVertical » Do 17. Nov 2011, 03:36
Hi, yes I used a 12 volt deep cell battery as a test load. I was reading about shaft power. This is my first attempt, could it be that is the maximum shaft power at those wind speed? I am fabricating and testing a similar sized C rotor or J shape in a few days and I will post results when available. Basically there are three factors I can change, the blades, the gear ratio, and the stators. Thanks for any help received. Best regards
