Kai Deng GTI300W Grid tie inverter reverse engineering
Beitragvon vasonline » So 3. Feb 2013, 15:11
Hi,
Excuse me for my English.
Entschuldigen sie for meine English.
I found this excellent forum by gooogling.
I will try to make a German translation if time. (my German is very bad, but I can read it)
Meine Deutch is sehr slecht, lesen ist Ok, aber schreiben is sehr schwierig.
I have two Chinese grid tie inverters. But the are not of the more familiar "Power Jack" or "Sun".
However I would really like to reverse engineer the microcontroller program.
The manufacturer is "Kai Deng"
They have the annoying bug that they need a rather large solar input (15W) in order to "power lock" stable.
I believe the current "step" is too big in the microcontroller.
Can you help me finding the microcontroller name?
It's name is sanded off :( Atmel?
I already found the other chip myself.
To the left it seems a connector for programming, just like the power jack/sun gti
I also upgraded the input capacitors to 2x10.000µF
vasonline
Re: Kai Deng GTI300W Grid tie inverter reverse engineering
Beitragvon andreas » So 3. Feb 2013, 18:10
Hello,
it could be a PIC.
Beitragvon vasonline » Mo 4. Feb 2013, 11:29
Hi Andreas,
Vielen dank :)
Many thanks :)
I checked most of the pin's and they all match with the PIC16F8.
So I will probably need to buy something like this?:
https://www.olimex.com/Products/PIC/Pro ... /PIC-KIT3/
vasonline
Beitragvon andreas » Mo 4. Feb 2013, 22:38
Hello,
the PIC: Codeprotection.
Beitragvon vasonline » Di 5. Feb 2013, 18:26
Hi,
Thanks for the answer.
Maybe I will try it...just for fun to see if it's readable.
Greetings,
Zuletzt geändert von vasonline am Mi 6. Feb 2013, 14:11, insgesamt 1-mal geändert.
vasonline
Beitragvon PetriK » Di 5. Feb 2013, 18:41
If i remember correct there is a pic based reference design and program available on microchip site. Assuming this is pic then maybe its not so far away from reference design.
PetriK
Beitragvon vasonline » Mi 6. Feb 2013, 14:11
Hi PetriK,
Thank you for your input.
I have found the reference design & installed the code on my PC.
We'll wait till my PIC programmer arrives.
Greetings
vasonline
Beitragvon vasonline » Sa 9. Feb 2013, 09:45
I measured the 5 pin's of the ISCP/programming connector on the left.
Whether is a PIC or not, they all went to the right pin's on the chip.
PIN 1 was already "square" marked.
I the meantime I updated the drawing:
vasonline
Beitragvon vasonline » Mo 11. Feb 2013, 16:16
Hi,
Today I got my PIC3Kit.
However I failed to connect to the chip.
Oh dear It appears you need to select the right pic type in mplab.
The list is very long...
Some not relevant output:
PICkit 3 detected
Connecting to PICkit 3...
Firmware Suite Version...... 01.28.40
Firmware type......................Baseline
PICkit 3 Connected.
Target Detected
Code: Alles auswählen
Target Detected
Target Device ID (00000000) does not match expected Device
ID (0c053000).
Target Removed
Target Detected
ID (0c053000).
Target Removed
Target Detected
ID (0c053000).
Target Removed
Target Detected
ID (0c053000).
Target Removed
vasonline
Beitragvon vasonline » Mo 11. Feb 2013, 20:41
I believe it's a PIC16F716
PICkit 3 detected
Firmware type......................Midrange
PICkit 3 Connected.
Target Detected
Device ID Revision = 00000005
How do I read it's memory? So far I see nothing at all when I select programmer --> read
vasonline
Mitglieder in diesem Forum: Majestic-12 [Bot] und 2 Gäste
